Results 1 to 3 of 3
Thread: Wiper upgrade
    Oct 2010
    Wagga NSW
    Wiper upgrade
    Hi all switching my mk4 rear wiper arm with the mr5 arm, anyone know how to get the mr4 arm off?
    Dec 2007
    Brisbane, Southside...
    Pop the cap off (it just clips in place). Then carefully pry/ease the arm off. A spray of WD40 or some other lubricant might be needed if it's stuck on tight. Be aware that the Aero wiper cap (MKV and Polo are the same) is too "tall" for the MkIV and you need to sand/cut back where it sits against the glass. If you don't it won't clip on properly and you also will scratch your glass. You can buy pre-modified caps from the some of the online sellers like ECS tuning etc.
    Hope this helps.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Oct 2010
    Wagga NSW
    Cheers for that Trent, I ended up getting it on, I used the mk4 cap! Had the shave a bit off in another spot but seems to fit well!
