Results 1 to 9 of 9
Thread: Rims fitting
    May 2009
    Canberra
    Rims fitting
    Hi Guys - I'm thinking of buying a second hand rims, I am sure it will fit in terms of PCD and ET, but I'm just wondering if the width won't fit my car.
    The Rims are from B5 A4 Audi
    and my car is Bora 4motion 2001 model.
    Can any one give me any info please.
    thanks
    2009 Tiguan TDI and 2007 Passat TDI
    Dec 2007
    Brisbane, Southside...
    B5 Audi A4 were PCD 5x112 i'm pretty sure whereas the Bora is 5x100 so the PCD is actually wrong and they won't fit without adapters or redrilling.
    In regards to the width question without knowing the ET and rim width we can't help you with whether they'll rub or not on your car. It's not like the A4 came with only one set of wheels so yeah it's impossible without more information.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    May 2009
    Canberra
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    this is the wheels im after
    18" Audi A8 Reps w/ Dunlop Sport Maxx Tyres 90% tread (eBay item 220802458007 end time 30-Jun-11 17:28:51 AEST) : Cars, Bikes, Boats
    Aug 2009
    They'll fit fine.
    Also use this offset calculator
    Wheel Offset Calculator
    Mar 2009
    Sydney boy
    Hi its says on the ad their 5x100 n 5x112 they will fit perfect with out any headaches.
    their cheap too(well starting bid is) shame about the gutter scaring.
    Albury, NSW Australia
    It doesn't say how wide they are, but being 5x100 ET35, they're probably designed for MK4s.
    As a comparision, my wheels are 18x8 ET32. If your new wheels are 8 inches wide, they'll sit 3mm closer to the car (less wide) than mine. This will change if they're 7.5's or 8.5. The tyres are also 235's, which is slightly wider than the "normal" MK4 size of 225 40 18. This will have an impact on your speedo reading.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    May 2009
    Canberra
    I yeah I know, I just have to put up with it until I got a new tyres, I want the rims baddley. I ike the look of your car gringo.
    Mar 2009
    Sydney boy
    hahaha thanks revhead1016.
    I got 20s on my 4 mo and its low and no problem with tyre rubbing front or back so i say get to bidding mate!
    hey about the gutter scars hit it with an vibrating orbital sander with 220 grit then smooth the sander marks with finer paper and respray em
    in a nice silveror charcoal metalic and your bora will look mean
    May 2009
    Canberra
    Quote Originally Posted by gringo_54_oval View Post
    will do that, thnaks mate
