My 2lt is around that, its manual 5spd.
so I was travelling to the northerm country yesterday with a friend and she noticed with my car doing little over 100kph the car revs stay at 3000rpm? Now is this right? My cars only a 99 1.6 sr? My friend has a 2012 fiesta 1.6 even she reckons her car doesnt get up to that many revs and hers is only a 5 speed box too
Any ideas??
yeah its normal for the 1.6 sr (my sister had one ) and for some reason they are geared really high so so it revs a lot at high speed , gets really annoying on the freeway especially on a long trip![]()
-2003 Vw Bora Vr6 4-Motion - Back From The Dead LiNk tO PhOtO Thread
-1993 Nissan Nx-R , SR20DE+T Project.
-1993 Kawasaki ZZR250 (grey import)"The StreetFighter"
What are the GTI's like? looking into a conversion soon so i wonder if they are a little better with that?
I find that even my R32 revs quite high. At 60kph in 5th gear my car revs at around 2000rpm. I found that most other 6 speed cars I've seen/driven do that in 4th gear. I thought it was a little odd but never really questioned it, I just assumed it was because they have a really tall gear set.
I would have thought that a car with a tall gear set would rev LOWER than one which has a lower set.
EG a 5 spd car usually has 5th as overdrive and is say 0.75:1 and when you drop into it the revs drop.
In my Cruiser 4th gear at 90kph gave 2350rpm.
Drop into 5th and revs dropped to 1900rpm
5th being a taller gear gives less revs, not more
My sons old Camry revved high and I found the diff ratio was the cause.
Putting larger tyres on makes gearing a bit higher and lowers revs as the wheels do less revs per km
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
You can fix this by changing the 5th gear in the box to a different one.
Get the final gear out of a different gearbox at the wrecker. Look for a busted diesel gearbox. They are geared for a more torquey engine and thus will run at lower rpm. Generally 5th gear is not the one that gets busted, so you can pick up this sort of stuff for next to nothing.
It isn't a hard job, you need to make sure you have the tools though (especially the gear puller).
Heaps more detail at this site:
5th gear swap on VW manual transmission
There are also companies online that sell even taller gears brand new, but generally it isn't worth the expense. There's also an extension you can buy to add a 6th gear, but it's expensive and you could buy a 6 speed box for less money (Gearbox Modifications | Eurotuning s.r.o.).
