On the Haldex coupling housing, about the right side driveshaft.
so is the haldex filter connected to the differential side which uses gear oil ,or the haldex clutch side of the diff ?
.very tight spot indeed....
There's a special wrench you can buy, or you can remove the brace in front of it, and remove the two front cradle bolts to lower the whole lot into a more accessible position.
thanks ..ill try the way of doing it without purchasing another special tool that i will only ever use once..
If I did them week in, week out, I'd have bought the tool. Just not worth it otherwise.
agreed...
