Check your fuses then get a VagCom scan
Hi All,
As the title states, my rev tacho stopped working today.
Not sure when this happened, I think it was working fine yesterday.
Any thoughts on what to try or look for?
Sash
The rev tacho would not have a fuse all on its own would it?
I would have thought the whole cluster would be on one fuse.
I'll check 'em all anyway.
I tried vagcom, said no error. Funny thing was that I could not do the output test..... like make the gauges move with the output test function.
Sash
I had my speedo stop working... that was down to a failed Vehicle speed sensor on the gearbox... but speedo sounds like engine speed sensor ?!... Is it still running ok? Could just be the cluster.
'03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
Checked all the fuses this morning, none were blown.
Anything else to check guys? What could it be?
Sash
Hi check the wiring loom under the battery, where the loom runs tight into trunking, have seen many looms/wires snapped in that area causing similar faults to yours...
