Results 1 to 7 of 7
Thread: Rev Tachometer Stopped Working
    Jul 2009
    Hi All,
    As the title states, my rev tacho stopped working today.
    Not sure when this happened, I think it was working fine yesterday.
    Any thoughts on what to try or look for?
    Sash
    Jul 2007
    Brissy
    Check your fuses then get a VagCom scan
    Jul 2009
    Quote Originally Posted by JustCruisn View Post
    The rev tacho would not have a fuse all on its own would it?
    I would have thought the whole cluster would be on one fuse.
    I'll check 'em all anyway.
    I tried vagcom, said no error. Funny thing was that I could not do the output test..... like make the gauges move with the output test function.
    Sash
    Aug 2007
    Five Dock, Sydney
    I had my speedo stop working... that was down to a failed Vehicle speed sensor on the gearbox... but speedo sounds like engine speed sensor ?!... Is it still running ok? Could just be the cluster.
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Jul 2009
    Quote Originally Posted by goodfella View Post
    Cars running fine, just the tacho stopped working.
    What else could it be?
    I know my battery isn't the greatest but it wouldn't cause this to happen would it?
    Sash
    Jul 2009
    Checked all the fuses this morning, none were blown.
    Anything else to check guys? What could it be?
    Sash
    Apr 2009
    Hi check the wiring loom under the battery, where the loom runs tight into trunking, have seen many looms/wires snapped in that area causing similar faults to yours...
