any one need to reprogram they remote. give this instruction a go.
Remote Control Key Fob Programming (1997 ON)
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second key.
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure is the same, except you press the unlock button 2, 3 or 4 times for the different remote.
For example : If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
Remote Control Erasing (1997 ON)
3. Press the remote control unlock button 5 times in 1 second intervals. A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory erase.
5. Switch ignition OFF, all remotes are now erased.
this is the site
http://www.vwdiesel.com/Program_Keys.html
2009 Tiguan TDI and 2007 Passat TDI
