Results 1 to 10 of 12
Thread: Replacing lower control arm bushing for a Bora V5
    Jun 2012
    Hi guys I just wanna ask if anyone has replaced the lower control arm bushings or the whole control arm?
    I went to a mechanic today and he said that they normally replace the whole control arm and not just the bushings it self.
    Would this be the convenient/hassle free job?
    cheers.
    I know a few mechanics down here that just replace the whole arm.
    The time it would take them to remove the old bushes and press in new ones + the bush itself was the same or more then getting a whole arm with bushes pressed in from factory. the arms themselves can be damaged too so if cost was the same id be going the new arm option
    Jun 2012
    Yeah that's what I thought also. The mechanic said the same thing its just not worth doing the bushings. Can you recommend some
    places around Sydney? I think its going to be cheaper to get the part from ebay and just pay labour to fit in.
    I only know of camden gti in sydney.
    otherwise have a crack at it yourself if you are going to buy the whole arms.
    just need a jack, two car standard, some sockets, spanners and an alignment when you are done. only 5 bolts each side and as long as you dont touch anything else at the same time, do the bolts up to the right toque settings, youll be laughing
    Dec 2008
    Sydney/Canberra
    Tooley Imports in Hornsby will sell you complete arms. They supply parts to all the specialist independants in NSW.
    If it's a manual, they're pretty easy. If it's an auto, you may need to lower the subframe for clearance.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Quote Originally Posted by Umai Naa!! View Post
    Replacing the bushes would allow you to go with S3/TT ones, which are longer lasting/stiffer. I don't reckon they would be available in a replacement arm to fit the V5.
    Jun 2013
    canberra
    there is a how to thread above here.you can use that as a guideline to do it yourself.
    Dec 2008
    Sydney/Canberra
    Not sure why you quoted me in particular, but yes thats an option as well
    '01 Beetle 2.0
    Wasn't to offend
    Dec 2008
    Sydney/Canberra
    It's all good
    '01 Beetle 2.0
