hi mate and welcome
The most common issue with the 09A is typically solonoids fail and this can cause all sorts of crazy stuff to happen.
Gears don't shift smoothly, rev hang, no reverse, can't get it out of Park etc..
The 09A box found in the AQN 2.3 V5 is made by Jatco in Japan. They make the box for a heap of manufacturers, Nissan, Jeep, VW, etc.. Which means parts are available and you can buy them without paying VW tax.
Rather than throwing a used box in and potentially having the same issue i would suggest getting it scanned with VCDS or VAGCOM (VW specialist will have this tool) and confirm what the exact issue is.
If it turns out you need solonoids, look for a repair kit to suit JATCO JF506E
JF506E, JA5A-EL, 5F31J, 09A - Jatco | Transmissions
I also have access to VW repair manuals if yourself or the mechanic doing the job gets stuck, just flick me a pm.
$3k supply and fit I could understand.
$3k just to fit is too much, it's not a new VW with mechatronics and all that bs- doesn't need hours of coding, it may not need coding at all if the old TCM (Transmission Control Module) is retained.
![Replacement Transmission VW Bora-screenshot-2025-01-24-123032-jpg](https://www.vwwatercooled.com.au/forums/attachments/f14/56285d1737682532t-replacement-transmission-vw-bora-screenshot-2025-01-24-123032-jpg?s=50b14ffd0235a48d71afdae172a7db7f)
Good luck!
