Results 1 to 5 of 5
Thread: Replacement Transmission VW Bora
    Jan 2025
    Hi everyone, MIG has suggested posting this on the Mk4 Forum to see if somebody can help, so thank you for any help.
    I am new to the Forum, just joined so pretty excited to be part of the group. This is my first car group forum so forgive my lack of knowledge. I have a 2003 VW Bora v5 2.3L , which i have owned for 15 years, it has served me pretty well, bar a few cheeky problems and electrical gremlins along the way and still really enjoy driving it. Recently though the Auto gearbox has given me much trouble, it started with intermittent loss of reverse gear, which then developed into permanent loss of reverse gear, and now it is slipping in forward gear. I wanted to keep the car so i hunted around for a used transmission and have finally managed to find a compatible unit from a wrecking yard. I have called around a few auto trans mechanics about remove and replace costs and am getting varied costs and varied answers regarding the need for re-calibration. Quotes have ranged from $1100 - $3000 and some mechanics have said it should be a straight changeover ( plug and play ) where others have said it will need a new module and re-calibrating ( re-programming )...forgive my lack of tech knowledge here can anybody shine some light on this subject for me please, before i proceed? Thank you very much everyone
    Apr 2014
    Penrith, NSW
    hi mate and welcome
    The most common issue with the 09A is typically solonoids fail and this can cause all sorts of crazy stuff to happen.
    Gears don't shift smoothly, rev hang, no reverse, can't get it out of Park etc..
    The 09A box found in the AQN 2.3 V5 is made by Jatco in Japan. They make the box for a heap of manufacturers, Nissan, Jeep, VW, etc.. Which means parts are available and you can buy them without paying VW tax.
    Rather than throwing a used box in and potentially having the same issue i would suggest getting it scanned with VCDS or VAGCOM (VW specialist will have this tool) and confirm what the exact issue is.
    If it turns out you need solonoids, look for a repair kit to suit JATCO JF506E
    JF506E, JA5A-EL, 5F31J, 09A - Jatco | Transmissions
    I also have access to VW repair manuals if yourself or the mechanic doing the job gets stuck, just flick me a pm.
    $3k supply and fit I could understand.
    $3k just to fit is too much, it's not a new VW with mechatronics and all that bs- doesn't need hours of coding, it may not need coding at all if the old TCM (Transmission Control Module) is retained.
    Replacement Transmission VW Bora-screenshot-2025-01-24-123032-jpg
    Good luck!
    Jan 2025
    Hi beale187, mate thank you so much for providing me with all that information and offering to help out with manuals, that's awesome! It's interesting, I had asked a couple of mechanics about the scanning tool to see if it was worth repairing, but was told it wouldn't have been worth any repairs given the car was found to have other repairs needed and would probably exceed the value of the car. I was honestly going to scrap it, but then came across a used trans to match mine with only 100k on it for $550 so i took a chance, hopefully i can find someone to install it for me at a reasonable price, under $1000. I will definitely keep in mind the repair manuals if the mechanic gets stuck. Really appreciate your help, cheers!
    Jan 2025
    Hi beale187, I thought i would keep you updated with the progress of the transmission changeover. So, i had the used transmission ( purchased from wreckers ) installed by my mechanic, however it is not shifting properly, it jumps first gear then revs out second before shifting, then third gear is a very harsh shift and shudders and vibrates through the car, on a positive note at least i have reverse in this one...LOL The mechanic has an auto electrician perform a full scan and rest of the elctricals with a specialised VW scan tool, but it didn't show up anything, no fault codes or anything, he said he reset shift points as well, but no difference, he did suggest to perhaps try an additive as a cheap try before spending $ on costly repairs. Could it be a faulty clutch system or solenoids or other? Now i'm not sure what to do, i don't want to spend anymore money getting diagnostics and repairs done on it, because it's an old car and the repairs will be more than the cars value. Should i call the wrecking yard where i bought the transmission from ad see if repairs to a faulty gear box would be covered under their 3 month warranty? Thanks for any suggestions you have
    Mornington Peninsula, VIC
    I am sorry to hear you still having issues Bora03.
    Was the fluid changed when the box was moved across to your car? or at least the level checked? (I believe it also has an internal filter that can be replaced)
    I would think most auto Bora's would have these issues at some point, at this age unless you want to DIY stuff, you are going to sink money into labor.
    If you want to take a chance, measure the solenoids like in beale187's post and replace them, or swap the 3rd gear shift solenoid from you old transmission to check, few hours labor and fresh fluid (Penrite's ATF FS meets Jactco's specs) remember to doublecheck the drain bolt is right; one secures the reverse band, and will cause your original fault again.
    otherwise, get your warranty if you can.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
