Yes, it's fine.
It's only 4Motion when the Haldex module says so.
Hi all,
I want to remove the FL drive shaft so I can put on a new CV joint.
My Q is: as I'm rotating the drive shaft to get access to the gearbox end bolts, being a 4Motion, can the back wheels be left on the ground so it can rotate??? I'm unsure as never done the on a AWD before.
Cheers for any advice
Yes, it's fine.
it is a 4Motion so i have to have all wheels off the ground I guess
neutral
MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
