My car is under a cover at the mo, otherwise I'd pop the bonnet and have a look at those clips you mention.
If they are plastic I believe (vaguely remember these clips elsewhere) that they have a seperate plastic centre like a cylinder. This needs to be popped out (from front to back),
so that you can pull the clip out (towards the back of the car).
If its all too hard and your not worried about damaging the clip, just pull it out or drill out the centre from the back of the clip and it should just pull out easy..
