Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: Remapping - MK4 R32
    Dec 2007
    Brisbane, Southside...
    That's a pretty tidy R32. Sounds good too.
    Have you seen this one that JBS built? This goes hard.
    Hey Gavin,
    Do you know if the OP has had his car dynoed yet and what type of results it came back with? If so are you able to post the run?
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    I don't Trent. I spoke to him the other night but he never mentioned it. I might recommend he waits until the weather cools down, probably won't pull the skin off a rice pudding at 44 Degrees, if my Ibiza is anything to go by.
    I'll ask him now.
    Feb 2007
    Hey guys, haven't had the chance to get it into the rollers yet, and won't be doing it for some time - ie. until the weather cools down! When we get down to around 25-30 during the day, I'll see what I can do
    Dec 2007
    Thanks guys. Let me/us know how it goes. Hopefully I will be going down one of the chip paths before the end of the financial year.
    Cheers,
    Trent
    Nov 2007
    Coffs Harbour
    i want more out of my chip....is there a different process or just a mapping tune
    Thanks JVL
    Quote Originally Posted by JVLR32 View Post
    Thanks JVL
    Ben had a Phase 1 Custom-Code map loaded to his ECU.
    http://custom-code.co.uk/index.php?o...=314&Itemid=80
    If that doesn't answer your question, please ask again.
    Dec 2007
    Still interested to know how they can get nearly an extra 32kW in the Phase 2 package as that's an incredible gain in power for an NA engine. Does it require race fuel or something?
    Also how much tuning is able to be done to get the most benefit out of things such as CAIs, cams, exhausts and exhaust headers?
    Cheers,
    Trent
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    I'll be honest Trent, I don't know what mods that gain is based on. I would imagine that you have to have all the hardware you have mentioned and it would be running on 98 RON.
    In theory a well tuned up modern engine, shouldn't have that much difficulty making 100hp a litre. E36 M3s are nearly there standard, I know they rev a bit harder but I don't think it's inconceivable.
    Have mailed C-C about this.
    Apr 2006
    VW Race HQ - Sydney
    I'll ask him now.
    After all the figures and formulae I posted up it dissapoints me that you as a tuner still dont understand about correction factors and dynos . A car should be able to be dynoed at any time , any temperature at any altitude and still have readings within 1% of each other . That is what correction factors are for .
    Thanks JVL
    You'll need race fuel and a re-tune
    You cant compare an M3 engine to the VR6 engine
    R32 head does not flow
    The piston speed on the R32 is greater than the M3
    Bore × stroke
    M3 91.0mm (3.58 in) 87.0mm (3.43 in)
    R32 85.5 mm × 92.8 mm
    Not to mention the head probably flows a lot more , M3 has better exhaust manifold and you paid some $50k more for the m3 !
    Nov 2007
    Coffs Harbour
    very interesting thanks Gavin
