2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Is there a advanced throttle body kit for a R
It could be retuned, but we would need a good case of how many & the same mods.
A piggy back would probably be going backwards, I have seen many "piggy back" systems fail to make the same horsepower on ME7 cars, and struggle to run nicely at all (only the couple I have seen). Full stand alone would probably be the go if you went for radical mods!
Question...throttle body,manifold worth it all not?
Correct - Time tuning costs dollars, so one off mods = uneconomical.
If we have a case for it here in Australia - Like Left foot braking modification - APR did that specifically for the Australian clients that take their MKIV R32's on the track - with the 80 + R32's we have done, we convinced them it was a worthwhile exercise
Your not going to get much more power unless you do hardware changes then change software to suit . You need to get more air into the combustion chamber to gain more power , its as easy as that , fueling can be changed a lot more simply by raising fuel pressure or putting in bigger injectors (once you get close to 100% duty cylce)
I'll disagree with Guy on the stand alone statement . The factory ECU is more powerful than the stand alone units available at the moment , in the mk4 r32 anyway . I would only go stand alone over factory ecu for a purpose built race car , even if its registered and driven on the street .
Interesting.....$s for bigger injectors?
$ for throttle boddies?
Yeah my thoughts for the distant future include things such as VF Stage II supercharger and cams. Haven't fully investigated it yet as that's something for later but if will of course be looking to see if things such as bigger injectors a DSG MAF etc would add to this as well.
I figure now is as good time as ever to start asking questions as of course the software is going to be needed.
Time and dollars... That's all I need...
Cheers,
Trent
