Results 1 to 10 of 11
Thread: Reliability of Turbo and Computer Upgrades / Engineering
    Mar 2008
    Newcastle, NSW
    Hey,
    I'm still looking at buying a Mk4 Golf GTI.
    I'm seeing a few around with k04 turbo upgrades, computer upgrades, and suspension upgrades.
    I have two questions;
    1) How reliable are these turbo and computer upgrades? (how long is a piece of string, but general comments would be great).
    2) Do these mods have to be engineered in NSW?
    Cheers Everyone.
    The K04-001 is quite a reliable upgrade. The outer housing is the same size as the standard K03 turbo and all of the ecu upgrades available through the many companys such as APR, GIAC, MTM, Superchips all run within fairly safe specs.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Mar 2008
    Newcastle, NSW
    does the upgrade need to be engineerd?
    Thanks again
    Mar 2007
    sydney
    Quote Originally Posted by Smitch View Post
    Thanks again
    no, you can really see a difference, its not classed a big upgrade, but does give good power increase..
    mk4 the mods begin for round 2 hahahha
    Your not physicaly modifying anything structualy so no - it doesn't requiring and engineering certificate.
    Mar 2008
    Newcastle, NSW
    thanks for your help.
    Suspension modifications need to be engineered though dont they. Is this a difficult task? I guess it depends on the units used now I think about it.
    Dec 2007
    Melburg East VIC
    no, rears suspension are easy to swap, front is a little harder especially drivers side because of the thicker drive shaft. just use spring compressor or turn your wheel full right and use some force to compress the spring to get the shock out of its position. i've had my k04 for about 1.5yrs, no probs so far
    edit: sorry didn't read ur Q properly, thought you were asking how difficult suspension are to swap, anyway you don't need a cert.
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    Jan 2008
    Quote Originally Posted by 99gti View Post
    If you talk to any police: anything non-standard needs to be engineered, else you are able to be defected.
    You may also find that a turbo upgrade and a chip may change emissions, and EPA aren't very friendly.
    With regards to suspension: Lowered vehicles can be defected. 100mm ground clearance is stipulated in Australian Design Rules (ADR), and if you're lower, you get defected. Friend of mine was NOT lower (so his car was legit), still defected, needed to be certified to clear the defect.
    Same deal with aftermarket rims.
    And yes, alot of people here may not have been pulled up for such modifications, but that does not mean that you couldn't be pulled up for it.
    Nov 2006
    You don't strictly need and engineering cert for any of that work and the police tend to leave dubs alone. (So no defect dramas)
    Redfern NSW
    given your concerns and questions I would say just buy a standard GTi
