Next come fitting the tail ends of the sway bar to the hanger brackets.
Basically, the further in (towards front of car) you mount the sway bar to the hanger bracket the stiffer the sway bar will act.
I have set mine up on the second last hole closer to the front.
Use the larger (and hopefully only remaining) bolts, placing them through the hanger and sway bar. Fit these off with the large washers and nylock nuts
Attachment 1315
Finally, once you have everything lined up OK, tighten all the nuts ensuring there is no free play.
With the U Bolts, I found that I couldn't tighten them as much as I would have liked for fear of crushing the hollow swingarm. I may just be being pedantic here, but I will keep an eye on it an monitor.
Don't forget to tighten them up after a week or so to ensure there hasn't been any loosening after the bolts stretch and settle.
Attachment 1316
Hopefully this is of some use anyway....
After taking the car for a quick spirited shake down drive, I definately could feel an improvement. As mentioned I have mine on the seconf stiffest setting and found it to be pretty good. For track work I will probably run it on the stiffer setting.
