It could be that there is some corrosion in there making it harder for hte piston to come back.
A caliper rebuild kit is pretty cheap locally (circa $30 IIRC) and a pretty easy job if you are a bit mechanical.
At least first, give it a bleed and see if any junk comes out. If its very dirty fluid, I would be doing a caliper rebuild. If not, perhaps look more closely at the handbrake lever on the back of the caliper.
Check the condition of the pads on each side of the rear - of the other side is notably more worn, the piston may well be partly siezed in the bore.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
