is this in a FWD ? if so just undo the shock, and pull the perch out, its easy as. plenty of people on tex have done it, i could do with mine out but i like my car with a bit of forward rake...
Gday folks, just wandering if anybody has removed the rear peches from BC coilovers?
Car sits ok...just want it that extra bit low. Not worried about comfort or handeling.
Also would any body be keen to lend a hand to do this or point me in the direction of somebody who can?
Ok so I'm about to remove the rear perch on my KWs.. Should I remove the whole perch or just the adjuster collar thingo? I'm led to believe this would be safer..
EDIT: Since I don't know how to describe things.. Can I just remove the purple bit, or do I have to remove the black bit too?
Id just do the adjuster first...
Wow, my Ta's must go low. I actually had to wind the rear of my car up a good 10mm to fit the LMs...
can pull both the mount out also, but just saying pull the adjuster first then see how your going for height
each one is different so i dunno how much drop youll get
