Results 1 to 8 of 8
Thread: Rear Perch removal on BC coilovers
    Sep 2011
    Gday folks, just wandering if anybody has removed the rear peches from BC coilovers?
    Car sits ok...just want it that extra bit low. Not worried about comfort or handeling.
    Also would any body be keen to lend a hand to do this or point me in the direction of somebody who can?
    is this in a FWD ? if so just undo the shock, and pull the perch out, its easy as. plenty of people on tex have done it, i could do with mine out but i like my car with a bit of forward rake...
    Apr 2008
    Quote Originally Posted by chaddy86 View Post
    I hope with this attitude you're not driving on public roads. Handling being your car's ability to go where you want it to...
    Nothing to see here...
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by Manaz View Post
    Maybe he only drives in straight lines on smooth rainbows. Hopefully.
    The rear's easy to remove man just search for some write-ups with pics and you'll be on your way. Don't waste your money paying someone to do it.
    VW Bora V6 4motion
    Jun 2009
    Melbourne, VIC
    Ok so I'm about to remove the rear perch on my KWs.. Should I remove the whole perch or just the adjuster collar thingo? I'm led to believe this would be safer..
    EDIT: Since I don't know how to describe things.. Can I just remove the purple bit, or do I have to remove the black bit too?
    VW Bora V6 4motion
    Id just do the adjuster first...
    Wow, my Ta's must go low. I actually had to wind the rear of my car up a good 10mm to fit the LMs...
    Jun 2009
    Melbourne, VIC
    Thanks Dylan, I knew you'd answer =] Yep I'll just do the adjusters first.
    I was surprised at how much gap the KWs had after being wound all the way down. Reading on the TA Technix they go down a hell of a lot more..
    VW Bora V6 4motion
    can pull both the mount out also, but just saying pull the adjuster first then see how your going for height
    each one is different so i dunno how much drop youll get
