Results 11 to 20 of 25
Thread: Rear passenger footwell wet
    Jul 2011
    South-East Brisbane, Queensland
    Quote Originally Posted by JustCruisn View Post
    It would be worth checking that the brown hose from the sunroof at the rear makes all the way down to the nipple behind the rear bumper.
    I found one of mine was not connected, water was pooling in behind the rear wheel. This was a few years ago after some body repair.
    I found yesterday that I forgot to replace the bung that I removed to let it dry out back in 2008. This was letting water in from underneath when driving at high speed in pissing rain, that was the musty smell I had for the last few weeks.
    How can I check that its all connected? Do I get in under the wheel lining or something? Or feed a tube through it to find out? I know they also feed down the c-pillar, I guess I will check there. I've been meaning to finish off my re-apolstering anyway
    Jul 2011
    I finally found what was causing the leak. I sort of forgot about it until it started raining again recently
    The seal beneath the door of the passenger footwell was so full of crap that water was leaking over into the car. I took all this dirt from the one door seal after removing it from the door, which was very simple. (Just pop it off)
    And for reference if people search this, its this seal;
    Dan!
    v5 Bora/Indigo Blue/Remus sports exhaust/JOM coilovers/Lots of DIY bits and Pieces/
    Aug 2007
    Hi mate have you dropped the roof lining in the rear and checked the tubes that physically fits to the roof. If you remove your rear roof handles and your c pillar trims you can drop the headlining a tad and that way you can see the hoses . What happens is the hoses lose resilience and get loose , water leaks past them and into the car, the hose gaps on the roof . Secret is to fit the hoses and bind them back within silicone rtv. Also blow air down the tubes to clear them of gunk, just done a mk4 gti for same thing
    Good luck
    Jmac
    Alba European
    Jul 2011
    Yeah, that was recommended in a vwvortex thread and here earlier. I could see that the water was running down the tubes fine and there was no wetness in the headliner or c-pillar, so I had to find how it was getting in. I noticed that the door sill was very wet in the back and after I cleaned out the seal and tested it again it wasn't, so I assumed that was the problem. We will find out soon if I'm right or wrong I guess.
    Thanks!
    Dan!
    Aug 2007
    Quote Originally Posted by Brisbane's Bora View Post
    Thanks!
    Ah ok then , i suggest you remove the door card form the door on the offending side and have someone with a hose on the outside hose the car down, you will probably find the door mebrane seal is knackered from being pulled apart in the past. Hose the car down with the door card off and you might see water seep passed the membrane, you can fix this with silicone.
    Good luck
    Jmac
    Alba European
    Jul 2011
    We need a 'like' button cause I would probably like all your posts haha
    Dan!
    Jul 2007
    Brissy
    You can "like" someone by clicking on the star thingy logo at the bottom of each post.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2008
    Cronulla, NSW
    about 2 weeks ago i got some whippa snippa cable and shoved it down the 2 front and 2 rear nipples. I then cleaned them from the bottom up too. the rear left was gunked up and hence the rear pass footwell was wet and soggy and disgusting.
    trust me, the water that came out was absolutely feral water, it stank and there was about 300mL at least.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Sydney, Australia
    Do these drainage pipes exist on the non-sunroof models? I think my problem is the door anyways, but just for future reference..
    ---------- Post added at 11:40 PM ---------- Previous post was at 11:38 PM ----------
    Is there a tube to drain from the antenna?
    Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
    Jul 2007
    Brissy
    The tubes are specific to sunroofs. The sunroof has a gutter that drains via the tubes.
    There is no drain on the antenna, it has seals both internal and external. The external seal is mostly cosmetic and often dries out and breaks, it is a cheap fix.
    MK4 GTI - Sold
