Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Rear passenger footwell wet
    Jul 2011
    South-East Brisbane, Queensland
    So its been raining for the last few days and I went to clean the interior of my car today to find the rear passenger footwell soaking wet. The floormat was soaked through. The wetness is only in the one footwell and stops at the hump under the front seat and the divider between rear footwells.
    Anyone have any idea where or how the water has gotten in? It almost seems as though the water has come up through the floor but are there any seals down low that may have cracked?
    Also, no one has been in the back of my car for about a week so I don't think it was tracked in somehow.
    Any help is handy!
    In return, the sexiest Bora I've seen (IMO)
    Apr 2011
    My Son had exactly the same problem with his 4 motion Bora after recent heavy rain, rear footwells soaked. From the photo i'm assuming you have a sunroof and the drain channels become blocked over time. You can get VW Service to fix the problem, which is what my son did, or if you want to DIY there is info on the internet detailing the procedure.
    Cheers,
    2006 Golf GTI DSG, Leather, Xenons, SatNav, Kufatec Module
    Jul 2007
    Brissy
    That's not his Bora ! But if there is a sunroof that would be the 1st culprit.
    My car has a musty water smell ATM. I check the sunroof regularly as it flooded the car a few years ago.
    I'm going to check the bungs on the floor. There are quite a few of them, there are 2 in the rear foot well on each side.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jul 2011
    From what I have read elsewhere the drains for the sunroof are two nipples in the door? I will have a look. And does anyone know how difficult it is to pull the rear carpet up? I dont want to do anything unreversable
    ---------- Post added at 12:09 PM ---------- Previous post was at 10:49 AM ----------
    "Yes your sunroof drain campaign is still open on your car. Time to make a visit to the dealer. If you complain about a bad smell in the car. They have been replacing carpet and padding for the bad drains. Good luck."
    Read that on vortex regarding a guy in the states that had a similar problem, did this happen in Australia aswell?
    Jul 2007
    Brissy
    Carpet is easy to lift up for inspection. Taking it out all together requires a lot of work.
    To get under the rear area remove the rear seat base. The carpet just stops under the rear seat.
    Pull the carpet forward enough to look under. There are about 4 layers before metal.
    You may need to remove the trim panels on the side near the doors too. It's all mostly pull clips in that area.
    MK4 GTI - Sold
    Peregian Beach
    There are 4 drains for the sunroof. Two exit at the 'A' pillar as I recall and are easy to see. Look for a black tube around one quarter inch diameter. I found just giving it a squeeze sometimes is all that is needed. There are also 2 at the back that exit under the car behind the rear axle. They are a bit harder to find. I have had both the back and front tubes block over the years and it has always been an easy fix.
    I have never lifted the carpets. Just leaving it in the sun with the doors open or windows down has worked. Probably the best is to sop up what you can with a large towel and then drive around with the air con on and that dehumidify the air inside the car and that will dry it out.
    Jul 2011
    I got in under the car and cleaned the nipples (lol) out a bit, then tested the sunroof by pouring some water into the drains. The front two and back left all worked fine after i cleaned them out but the back right didn't seem to do anything. Its wierd because it's the left footwell that was wet. Pulling up the carpet tomorrow when I'm free to have a better look, good thing the forcast rain hasn't come.
    Thanks for the help!
    Mar 2011
    Chermsdie West, QLD
    no need to pull up the carpet just leave it running with the aircon on and leave windows down will be fine.
    Jul 2011
    Quote Originally Posted by debo View Post
    I was pulling up the carpet to check if their are any holes in the plugs that are underneath it, not to dry it. Its been raining for almost a week straight now so i still havent done it but the same footwell is at the same amount of wetness, though I havent driven much. Still thinking its the sunroof. Might try a DIY off vortex to fix it.
    Jul 2007
    Brissy
    It would be worth checking that the brown hose from the sunroof at the rear makes all the way down to the nipple behind the rear bumper.
    I found one of mine was not connected, water was pooling in behind the rear wheel. This was a few years ago after some body repair.
    I found yesterday that I forgot to replace the bung that I removed to let it dry out back in 2008. This was letting water in from underneath when driving at high speed in pissing rain, that was the musty smell I had for the last few weeks.
    MK4 GTI - Sold
