If it's still got the original discs on it, pull a wheel off, and give the 'hat' of the disc a good clean. The part number will be etched on the steel. It'll start with 1J0 most likely.
Otherwise, find the data label, which will be stuck to the boot floor, next to the spare, and in the front cover of the service book, and look for the PR numbers 1KY, 1KQ, 1KW, 1KS, 1KV, or 1KK. One of those will detirmine what rear brakes it has, and how to match it up in the parts catalogue.
Volkswagens are a nightmare to get brake parts for non-genuine, if your supplier can't match it all up using your VIN.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
