The dump pipes are cast and you must run a CAT of some sort. Cops are catching on to gutted cats these days with infra red heat guns. They will get a reading from the inlet and outlet of the cat and if theres no difference in temp, you get reamed.
Hi Guys,
As the title suggests I have a quick question in regards to the Exhaust / Cat / Dump Pipe of MK4 GTI's 1.8L Turbo.
- Is the standard dump pipe off the turbo (where the four bolts are) Mild Steel / Stainless Steel or Cast?
- When people upgrade the exhaust system, do you also change the factory Cat? (I have been told that these Cats are Euro 4 and can not be replaced by just a standard performance high flow cat.) or do you not use a Cat altogether? (Is there legal issues with that???)
Any help would be great!
Glenn
Thanks for the quick reply guys!
i also have a 2.5" and hi flow cat...no probs
MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
What are the cops like towards butterfly valves like the varex ?
What they cant find, they cant shaft you for. You just have to be smart about what you do.
