Its Part of the ECU software, we can actually switch it on or off as the customer likes with the APR Remap.
If your car did have it & now it doesn't then you just need to switch software (Assuming you are chipped)
Guy, I would be interested in seeing if this is something that could be done...
I spoke with VW this morning also and they advised that the display is via an LED not a bulb. So if the LED is not actually in the dash cluster it will not be able to be activated.
But I am happy to see if we can get it working...
Glenn
Guy - Do you know if it is a similar proposition for the a3s? Is the light actually in the dash?
I'm still trying to figure out how to make the cruise control work!
Flick the switch on and then press set...
Let me know if your dash light, lights up!
