Results 1 to 10 of 20
Thread: Random Stalling, hard to start and EPC light
    Apr 2014
    Penrith, NSW
    Dubbers,
    My 4motion stalls at random (whilst driving) and can be hard to start whether it's warm or cold.
    When it stalls the battery and EPC light come up on the dash.
    I've tested the battery (and swapped batteries) still no luck.
    I've tested the alternator and it's charging at 14.1V and about 13.5V when under load.
    I've swapped out the fuel pump relay
    I can hear the fuel pump prime when I open the door
    I've scanned it with VCDS and it's not showing up any codes. Mind you when it's been scanned it's been stationary and no lights on the dash (hard to scan it whilst I'm driving and it randomly stalls)
    I'm thinking... It could be a Crank Angle Sensor. Anyone have any other suggestions?
    Also is there anyway in VCDS to see historical DTC's? Like when a DTC is logged but clears itself, anyway to check that even if the error is not present at the time of the scan? Hope that makes sense
    Cheers,
    Mar 2017
    Could be the cam position sensor? I had a similar issue on the 1.8t, got a good price buying both cam and crank angle and replaced both and it fixed it.
    I've previously looked into if there is a code history and as far as I found once they are cleared they're gone.
    2002 Golf GTI - K03S | 3" Downpipe | 312mm DBA T3 Slotted with Forza Pads | | Forge 008 | Forge Hoses | ECS Performance Mounts | R32 and Urethane Bushings | Pipercross Filter | Sachs VR6 Clutch with 14lb Balanced Flywheel
    Apr 2014
    Penrith, NSW
    Did you have any DTC's on either sensor? Any suggestions on diagnosing either?
    Feb 2014
    Batemans bay
    Air flow meter .....
    Unplug it and try it.
    Car should run better than what you’ve got now.
    If the symptoms remain then prob not the AFM but sounds like what mine was doing when mine failed .... only genuine Part fixed it.
    Apr 2014
    Penrith, NSW
    Sorry swapped that also, forgot to mention.
    Apr 2014
    Penrith, NSW
    Hazard of owning 4 MKIV's, part swap frenzy.
    Feb 2014
    Batemans bay
    Unplug it and try it ..... my symptoms were identical
    Apr 2014
    Penrith, NSW
    Thanks mate, I'll give it a run over the weekend with it unplugged. Too risky during the 350km a week run to work.
    Apr 2014
    Penrith, NSW
    No luck running without MAF. Stalled twice and was still hard to start occassionally
    Jun 2011
    Crank sensor will typically only happen when car is hot, once cooled off will start back up without an issue.
    Checked battery terminals?
