Bump
Surely someone has had track experience and can offer some brake pad advice.
I'm going too bleed my brakes firstly.
Anyone running steel braided brake lines?
Hey y'all,
The stock pads I have suffer extreme brake fade.
What brake pads do you suggest to run at the track?
Do I run the track pads all the time? even when not on the traqck?
Do I just change the front brake pads since they are going to be taking a majority of the stress? or both front and back?
Thanks in advance.
Bump
Ferodo 2500's are a very good pad to run as a street/track application.
Mine have done nearly 40k including a fair few laps of Wakefield and Marulan.Still plenty of material left on them.
Work well from cold no noise[standard discs]-and very good with repeated applications when hot.
Had standard rear pads,recently replaced them when they wore out.
Running Hawk Ceramics on the rear-can't say I've noticed much difference.
Definitely replace the brake fluid with something like AP Racing,Motul or similar.
It makes a big difference.
Standard brake lines are fine if they're in good condition.
What exactly do you mean when you say you have extreme brake fade?
Is the pedal going soft and spongy (fluid fade) or is the pedal staying firm and the car not pulling up (pad fade)?
Pad changes will not cure the former, only the latter form of fade.
Greg at GSL Rallysports (site sponsor) recommended to me that I should change my rotors if I were to use track pads as the pads deposit some of their material on to the rotor and this is what give the proper working friction of the pads. Without a rotor change, you need to bed the pads in by progressively braking harder and longer over a period of time.
DBA Bulletin - Basic Initial Brake Bedding In
Brake Pad Bed-In
Instructions for bedding in your brakes
For road and track use, he recommended me Remsa and QFM HPX pads while for pure track (or also hard road) use, he recommended the QFM A1RM pads. If you don't brake hard enough with track pads in daily use, you will need to bed them in again before track use.
Since you want the braking proportion to stay consistent, you should change front and rear pads to the same compound unless you are trying to correct a brake imbalance issue.
But contact Greg for the full picture
Resident grumpy old fart
I use the Ferodo 3000 R compound on my Polo - I did try the 2500s but I found they weren't withstanding longer track sessions and whilst they were still providing stopping power, the material was melting onto the rotors which required machining after every track day. For reference I'm running the Brembo 323mm brake upgrade supplied by APR.
The 3000s have proven much better - no problems with the material coming away on the track and no fade at all. They aren't as street-friendly as the 2500s though - they squeal like a stuck pig under low-pressure, low-speed braking such as coming to a stop at every set of lights. Dust isn't a big issue but I've got black wheels making it less noticeable anyway.
Have a look at GSL Rally sport, they are a sponsor. They do nice pads, very price competitive and can offer a few different products.
If you can replace your own pads, I'd recomend a set that is designed for the track only and swap them out before you leave the track.
What car are you running? Front pads tend to do most of the work...
I have run a bunch of different compound brake pads on stock rotors,
Hawk HPS+ (i think they are called) are awesome, they are very noisy though and i get people yelling at me "change your brake pads, you don't deserve your car" I'm sitting there thinking doh.
EBC Redstuff on stock rotors are great compromise of street track, aren't too noisy but arent as good as the ceramic blend compounds.
EBC Yellowstuff are good too, but again are quite noisy, or perhaps its the other way around.
Swap out if you can and get the most aggressive pads you can, but just do the fronts, 95% of the brake pressure is toward the front in high speed braking anyway.
Also, some good quality braided lines and high temp brake fluid is essential, will nearly make as much difference as the pads themselves.
'76 Mk1 LS
'04 Mk4 .:R32
'09 Audi S5
Im running a golf iv gti with custom code stage 1... nothing special, but just taking all the precautions.
It doesnt take long for the pads to fade <15mins at high speeds... some corners are braking from 140km/h to 50km/h, others are 80km/h to 10km/h... anyway when approaching some of the final corners.. I am putting my foot on the brake, nothing, further, start to panic, brake all the way, and their was mininal braking affect... when pulling up to a car spot, with a brick wall right in front.. going about 5km/h.. the brakes barely worked and i nearly rolled into the wall.. lol..
I must admit I have not changed the fluid lately, for over 1.5 years now... so I definitely have to do that.
Thanks to everyone for the information you have provided.. ill work with that and see what I can do to improve my braking.
But is
the pedal going soft and spongy (fluid fade)or
If it's the first, then change your fluid before spending any extra money.
Brake fluid absorbs moisture over time. Renew your brake fluid and bleed and you should have a a good hard pedal.
For track use, you could use Castrol SRF or Motul RBF600 brake fluid. For track pads, you have a good choice of; Pagid, Hawk or QFM A1RM.
