Results 1 to 10 of 17
Thread: R32 Xenon Problem HELP!!!!
    Feb 2008
    New Zealand
    What the hang!?
    i plugged in my vag com tonight.. it appears i cant access the xenon range controller or the leveling controller it looks like neither exist or somthing..
    im starting to think my car doesn have auto levelling xenons.? is this possible with factory xenons?
    What controllers is your car supposed to have with factory fitted xenon head lights..
    i remember it has thrown a code in the past saying there is an ignitor issue with the drivers side ignitor.. this issue doesnt register any more?? yet i still know my Drivers Side head lamp doesnt fire every time..
    this is driving me friggen wally..
    i want my auto levelling h/l's
    its driving me bonkers..
    am starting to think the head lights aren't auto leveling at all.!
    jump in the BMW 650 and the head lamps are constantly changing level as i go up driveway inclines etc..
    the R32 lights just sit... grrrr
    gonna pull the f*%kers out i guess and have a play..
    this gets to me..
    help
    do any other 2003-2004 R owner know what modules their cars internal network has with regards to the lamps and adjustment of autoleveling..
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Jan 2007
    I've asked Graeme to answer your question as he explained it to me and I'm buggered if I can remember his specific answer. Suffice to say you can't access the module in Vagcom but they do work. I can attest to this as when I put my two 18 spares in the boot in prep for a rally when I turn the ignition on without starting it I can hear the light motors working. It actually freaked me out the other day as I had loaded a heap of stuff into the car as we were moving and then decided to quickly scan the car before I packed the laptop away, when I turned on the ignition I could hear the Xenon motor (not the fuel pump priming sound) buzzing and clicking for around 15 seconds as they self levelled due to the increased weight in the back.
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Nov 2006
    Brisbane Qld
    VAG-COM Programming Procedure for Auto-leveling on 2003+ style OEM Xenon Headlights
    Before you begin, please be sure you are on level ground, that the parking brake is not engaged, and that there is no one
    sitting in the vehicle.
    Step 1.
    Start the VAG-COM, make sure the ignition switch is on (engine running or not running) and the headlights are on. Connect to address 39. This is your passenger side headlight leveling controller.
    Once you are connected note the current soft-coding number.
    Select 08 – Measuring Blocks
    Read channel 003 (hit Go!)
    After the lights have been on for at least 1 minute, the value in the first column should be between 30 and 40. This is the current wattage.
    The value in the second column should be between 68 and 102. This is the current voltage.
    Hit Done, Go Back
    Now select 07 – Recode
    Enter the appropriate coding from the list below:
    00001 - Golf 2 wheel drive
    00002 - Golf 4 wheel drive
    00003 - Jetta/Bora 2 wheel drive
    00004 - Jetta/Bora 4 wheel drive
    Hit Go! and the controller should reload with the new soft-coding shown in the controller information
    If the recode was successful, exit the controller.
    Step 2.
    Now connect to address 29. This is your driver side headlight leveling controller. This is considered the master controller and will be the one we use to initialize the auto-leveling system.
    Once you are connected you should see the following display:
    Read channel 002 (hit Go!):
    The value in the first column is the signal from the front axle leveling sensor. The value should be between 1.6 and 3.0 volts
    The value in the second column is the signal from the rear axle leveling sensor. This value should be between 1.6 and 3.0 volts.
    IF THESE VALUES ARE NOT CORRECT, please go back and read the fault codes (02 – Fault Codes). Once you have corrected the problem (voltages are within limits for both sensors), continue. Please note, if your vehicle is lowered, you may have to make modifications to your mounting bracket so that the “at rest” voltage readings are within specifications. Ideally, the voltage should be above 2 volts and below 3 volts. If these voltages are not within specification, the software will not allow you to proceed.
    Now read channel 003 (hit Go!):
    Verify that the value in the first column is between 30 and 40 watts.
    Verify that the value in the second column is between 68 and 102 volts
    Hit Done, Go Back
    Enter the appropriate coding value (Same as previous headlight)
    Step 3.
    Turn off the ignition and headlights, then turn them on again. This will reinitialize the system.
    Reconnect to Module 29
    Now select 04 – Basic Settings
    Enter channel 001 and hit Go!:
    The screen should read Wait. While this is happening, the leveling motors are returning to the initialization position. This can take up to 30 seconds
    The message should then change to Adjust Headlights:
    Using the manual screws, adjust the horizontal and vertical positioning screws to level the beams. Using the Bosch xenon headlight aligning system at your dealer or service shop is the most accurate(and quickest)means to properly aim your headlights.
    Once you are done aiming, hit Done, Go Back
    Now enter 04 – Basic Settings again
    Enter channel 002 and hit Go!:
    A message should appear Reg. Position Learned
    If a message appears stating Unable to Program or something along that line, read the fault codes, fix the problem, and do the coding procedure again starting at Step 3. If you did not go directly from channel 001, to the menu, back to basic settings, and then channel 002, you will get an error as well.
    If the settings were stored properly, CONGRATULATIONS, you are done!
    Simple.
    Jan 2007
    Quote Originally Posted by HitmanR32 View Post
    What the hang!?
    this gets to me..
    help
    I don't think the auto-leveling headlights work the same as in your BMW. This has come up on VW Vortex before, and IIRC the R32's lights level at startup but do not change dynamically as you are driving.
    Mar 2008
    Perth WA
    My range rover sport, xenons auto levels at start up, has a light out the side when turning and the lights turn aswell as u turn.... but i dont think they go up and down as u drive... they may do... hmmm
    and my bmw 840ci is too old for auto level lights
    and my vz clubsport only has xenons on high beam... cheap ****... lol
    and the golfs only a IV gti... hmmmmmm another reason too get a r32...
    Nov 2006
    Brisbane Qld
    R32 does NOT have dynamic levelling, however, when you start the car, they will adjust for the load.
    May 2007
    Moonee Ponds
    dont suppose it would be to hard to make them dynamically level than I guess
    Nov 2006
    Brisbane Qld
    The Golf has what is known as "Automatic Light Regulation". The control module is mounted in/on the headlight.
    The Passat comes with either "Automatic Light Regulation" or "Dynamic Light Regulation". The control module is mounted in the centre of the boot lid.
    May 2007
    Moonee Ponds
    Would that have come on the Passat W8 ?
    Nov 2006
    Brisbane Qld
    You mean one of the 13-odd that was actually sold here?
