Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: R32 tacho on a GTi
  1. #21
    Feb 2008
    Auckland NZ
    i'll have to double checl exactly.
    But fom memory after logging into the 17-cluster. Then do to adaptation.
    in there you either got the 4 digit code there or you had to choose the channel to change. I sold my Mk4 GTI today, so i will have to look on the girlfriends GTI tomorrow on monday when i get a chance. than i can confirm exactly. This is all done with Vag-com Ver5 onwards.
    Manaz - i'll have to find the coding, this mod i did do almost 8 months ago.
    If i find the code i'll PM them to you.
    Audi S4 (2001) - Imola Yellow
    Secret Project
  2. #22
    Nov 2006
    Brisbane Qld
    All R32 clusters are IMMO 3.
    Just change the softcoding to suit your car.
    On my R32 it has softcode 07700 from the factory. Vary your first three digits to suit.
    Our R32's here do not have the oil sensor in the sump.
    You just code the cluster to have "Fixed Service interval without sensor" in the adaption channel for the service intervals, then you should not get any oil sensor warning.
    If you do, then you can add this module:
    http://www.zusatzinstrumente.de/htm/togsim/prod.htm
