Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: R32 rotors!!!!!
    Apr 2008
    Quote Originally Posted by andrew View Post
    is this for the pair price or single becouse when i tried to buy it seems to be single one price ,, at germanautoparts they seem to be cheaper germanautoparts.com
    Here you go...
    Quote Originally Posted by ECS Website
    OEM Mk4 R32 Brake Rotor (Pair) (334x32) - $359.95 w/ Free Shipping to the Australia (normally $400 plus shipping)
    Nothing to see here...
    Jan 2007
    It is for the pair as per the advert
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Red face for the 4 motion
    do you have to change callipers and pads as well if upgrading to these on the bora
    i know the advert is for the pair
    Quote Originally Posted by quozl View Post
    but you try buying the quantaty will show 2 and the price 7hundred something
    Apr 2008
    Yes - calipers, carriers and pads all need upgrading to use the R32 rotors. Bora V6 4Motion front rotors are 312mm, I suspect the V5 and 4-cylinder Boras have even smaller front rotors (288mm would be my guess), the R32 rotors are 334mm diameter (and thicker too - 32mm thick vs 25mm for the Bora V6 4Motion).
    You can get a second-hand R32 upgrade (calipers, carriers and perhaps pads/rotors) for around $1200. I think there's a set for sale in the trading forums at present.
    One thing you need to realise is that you don't get much better braking at road speeds with an upgrade of rotor size alone - there's a small advantage due to the mechanical advantage of having the calipers sitting further out, but that's probably countered by the larger unsprung mass and rotational inertia. The main advantage comes in resistance to fade over repeated stops, as the larger rotors hold more heat - most useful on a track, or perhaps under extended periods of high speed braking (coming down a high-speed hill for instance, where you're braking to keep the car from exceeding the posted limit). You're often better going for better pads and fluid if you want better day-to-day braking performance.
    Apr 2008
    Sure - if you try to order four rotors (two pairs).
    You want to select "1" as the quantity, as they are sold as pairs.
    1 pair = two rotors.
    2 pairs = four rotors.
    caliper
    Quote Originally Posted by Manaz View Post
    thanks guess i will stick with my callllliiiiipppeeeerrrssss
    Apr 2008
    As I just edited into my post - you could go for better pads and fluid for an often surprisingly effective "upgrade"
    For pads, there's plenty of options. Ferodo DS2000/TS2000/Ferodo Performance are all the same as far as I'm aware, and should be decent. GSLRallySport have some QFM pads that they're offering good prices on that you could consider too.
    For fluid, get Super DOT4 or DOT5.1 - they're the same thing. Don't go for DOT5 (it's not compatible with most brake systems).
    When it comes time to replace your rotors, DBA do some decent rotors - their slotted street series to suit a Bora V6 4Motion are about $180 a pair for the fronts, rears are about $160 a pair - for V5/4-cylinder models you'd probably pay a little less. For around $260 a pair IIRC, you can get slotted 4000 series rotors from DBA - they're a better overall design than the standard street ones, and would probably handle a bit of light track work a little better if that's your thing.
    The next step then would probably be braided lines - if you go that way, just make sure they're ADR compliant (and marked as such - if they're not marked, they're not compliant, despite what some places will try to tell you).
    Dec 2008
    perth
    is this still available? my r needs new rotors asap!
    black mkIV .:R32 #001/200
    04 black new beetle turbo
    matt black 1970 beetle- low n slow!
    Jan 2007
    Yes follow the link in my original post
    My Garage
