Results 1 to 10 of 10
Thread: R32 Problem
    Aug 2008
    R32 Problem
    Went for a drive on friday and was frightened with a stop sign in my cluster, saying to check my coolant, soon enough I arrived at the servo and saw that my coolant was leaking lyk a b*tch, let the car cool down then topped up with water, it still leaked the next morning when went for a test run, is this a problem I can fix myself cheaply and effectively or do i hav to muck around with VW service center's? Im guessing the pump has been disconnected (but i don't know much)
    Thanks
    Tom
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    The pump won't be disconnected mate.
    Where is the coolant coming out of? Is it overflow, has the cap been fitted correctly, there's a rubber O ring in it and they sometimes get out of the groove and allow fluid through.
    Aug 2008
    nar it is from the bottom of the car, u can see it dripping out
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    Aug 2008
    under the car?? lol, um just where the bumper/skirt starts, quite central position. Can't see anything from a birds eye position of the engine
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    Could be a hole in the rad then. A trip to a mechanic would be my advice and carry some water with you until you get it diagnosed.
    Dec 2007
    Brisbane, Southside...
    Could be a the radiator hose down the bottom on the engine side of the radiator fans.
    When the R32s were first delivered this pipe went straight across and the fans actually hit the pipe causing it to go bust. There was a free recall done to replace the pipe with a kinked type that the fans did not hit. Might be worth giving VW a call to see if this has been done and if this is the cause of your coolant leek. They shouldn't charge you anything if this is the case.
    I would've thought this would already have been done on all the Rs by now as from what I've heard the fans chew through pipe in about 1000kms or so.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Nov 2007
    Coffs Harbour
    ohw man touch woodno probs yet!.........hope alls well Tom
    Aug 2008
    this car has done 65,000 kms so i think that might have been done before i got it, will be calling vw tomoz, thanks for the help guys, will let u know the diagnostic,
    Cheers,
    Tom
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    Jan 2007
    Treza is correct in his assesment. The same thing happened to Graeme86, there were a certain number of cars in a particular VIN range that had the hose fitted incorrectly. If you speak to Graeme he will be able to give you the notice info from VW regarding it and the part number to replace the bottom hose.
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
