There's more than that on the the R32.
There's approximately 7 torx screws under each wheel arch depending on how many got installed at the dealer.
There's three bigger torx screws beneath the center VW grill (be careful when you pull this out not to break the clips). Lift upwards on the grill to get it out and flat blade screwdriver on the center clip above the VW emblem. You don't need to pull the grill off completely (ie. removing the bonnet tab). Just lift it up to get to the screws and to remove the bumper.
There are two nuts on the left and right side bottom honeycomb grills. These grills just pop out pretty easily.
Ambient temperature sensor on the passenger side behind the bottom honeycomb grill. Make sure you don't forget this one.
3 or 4 torx screws on the bottom splash guard up near the sump etc. You don't need to remove the ones all along the bottom of the bar with the splash guard as by removing these other ones the splash guard will come off with the bar.
Pull the bar straight towards you horizontally and it will just slide straight out. It slides straight back in as well but having two people to line it up always helps.
Once you get the headlight out you'll see how that the Xenon ballast just unclips and you can move it to get to the parkers which just pull out. That is unless you have really big hands.
That said once you've pulled the bumper off and worked out how to do it, it's easy as.
Cheers,
Trent
