Results 1 to 8 of 8
Thread: R32 headlight bulb replacement
    Aug 2009
    Campbelltown, NSW
    Thanks Treza... I knew I had seen something about it somewhere
    No way I can get my hands in there... I can't even get the xenon transformer out... Think I might look at removing the bumper... My dad and I already contemplated that already! How hard is it to get off?
    Nov 2008
    Sydney, Macquarie Park
    Quote Originally Posted by MAC883 View Post
    its relatively easy actually. I usually do it myself, so its a bit tricky putting it back on, but no biggy. the grill just unclips and there are 7 torx screws along the bumper (two sneaky ones behind the lower grills) and another 4 along the guard lining on each side, and a temperature sensor behind the passenger side grill. there is a video on youtube...http://www.youtube.com/watch?v=qfoVOpRsNvo
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by Yevvy View Post
    There's more than that on the the R32.
    There's approximately 7 torx screws under each wheel arch depending on how many got installed at the dealer.
    There's three bigger torx screws beneath the center VW grill (be careful when you pull this out not to break the clips). Lift upwards on the grill to get it out and flat blade screwdriver on the center clip above the VW emblem. You don't need to pull the grill off completely (ie. removing the bonnet tab). Just lift it up to get to the screws and to remove the bumper.
    There are two nuts on the left and right side bottom honeycomb grills. These grills just pop out pretty easily.
    Ambient temperature sensor on the passenger side behind the bottom honeycomb grill. Make sure you don't forget this one.
    3 or 4 torx screws on the bottom splash guard up near the sump etc. You don't need to remove the ones all along the bottom of the bar with the splash guard as by removing these other ones the splash guard will come off with the bar.
    Pull the bar straight towards you horizontally and it will just slide straight out. It slides straight back in as well but having two people to line it up always helps.
    Once you get the headlight out you'll see how that the Xenon ballast just unclips and you can move it to get to the parkers which just pull out. That is unless you have really big hands.
    That said once you've pulled the bumper off and worked out how to do it, it's easy as.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Aug 2007
    Perth, Australia
    My parkers blew after a few months of owning the car and i never bothered to replace them. They were an ugly yellowish colour and when you get the xenons going it looks wrong to me. I prefer having 2 bright lights on the front
    1991 BMW 318is RED E30
