Results 1 to 4 of 4
Thread: Purchasing Mk4 Golf SE 2.0
    Jul 2007
    Blue Mountains
    Hi Everyone,
    I'm thinking of buying a MK4 2.0 litre golf. I was just wondering if there's any problems I should look out for, for this model.
    Deek
    Aside from the usual (check the oil level and colour/consistency, check for engine and gear oil leaks, see how it starts up - cold, check if it blows smoke from the tailpipe, check the gearshift quality, does the clutch slip, clicking sounds from the CV joints, tyre treads, etc):
    Air conditioning - check if the compressor is noisy and how long it takes for the air to turn cold. Any longer than 30 seconds is not good. My compressor failed recently, cost around $900 for my local air con specialist to replace.
    If it has power windows - check that they all go up and down fine (the clips that hold the window glass to the mechanism always break eventually, and the glass falls into the door - very very common with Mk4s). This is a major pain. My drivers door window mechanism broke a few months after I bought my GTI. I'd recommend getting some repair kits from the UK just in case.
    Check that the door locks all work, as it's very common for the solder joints inside the lock module to fatigue and crack.
    Ride quality (condition of the struts and bushes). Suspension noises, knocking, etc. Worn out bushes on the front control arms and rear axle beam, creaking on full steering lock indicates worn out strut-top bearings, none of these things are unusual from what I've heard.
    I only have experience with the 1.8T so I can't comment on a 2.0, engine-wise.
    Dec 2007
    Girraween
    Adding and commenting on the post above:
    Window regulators arent as common now. I havent sold a window reg kit in over 6 months.
    Air conditioning also isnt common, I could sell a compressor and have Seb fit it for less than $800.
    C.V. joints arent common, The drivers inner C.V. boot leaking is common. Once you get a leak its probably easiest to recondition the whole shaft. Dont bother buying new shafts from overseas that are cheap, they are usually out of balance.
    Creaking when turning is usually sway bar bushes.
    Other things to note are:
    Coolant flanges are starting to leak now.
    Rocker cover gaskets require replacing
    coolant bottles are also going brown with age
    There is more but they are a fairly reliable and its usually small issues with them
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
    Jul 2007
    Blue Mountains
    Thanks Fellas, much appreciated
    Deek
