Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: problems under high boost
  1. #21
    Feb 2009
    How did you come to the conclusion to use 7 (too cold!) in a stage I car?
    Quote Originally Posted by bujna View Post
    I did check the gaps before i installed them and they were at 28. They seem to be at that gap by default. I'll pull them out on the weekend though and see if the gap has changed. If i don't get any luck there, then i'll change to the bkr6e's you mentioned and see how they go.
    Thanks Gav! Once again
    I haven't found anyone that does the BKRxE lower than 1.1mm or 0.032
    You should always check the gap from factory.
    With a mild stage I tune, yoiu could probably get away with 0.030.
    In your pics, the 7s don't look like they're gapped to 0.028.
    I just re-gapped mine tonight to 0.027, and they're much smaller than your pics indicate.
    My take:
    I'm guessing you have a ignition controller (as you said you replaced this part) and coils.
    A good conversion is to switch to "newer" coils.
    You need to be handy with a soldering iron and electrical diagrams.
    The advantage? Since these newer 1.8T cars had to comply with more stringent emissions, they also provide a better/higher voltage.
    This allows you to get away with more gap and tiny bit more powah on the dyno
    00 A4 1.8TQMS GT2871R powered - Gone
    BMW 1M
    MK7 '19MY Golf TSI Trendline
  2. #22
    Dec 2007
    Quote Originally Posted by gmx View Post
    My take:
    I tried the 7's previously based on some postings over at vortex. I read that the rule of thumb was go a step colder every 50hp higher than stock. I figured i was probably most of the way there.
    I think i probably was a bit rough with setting the gap previously. I made sure it was absolutely tight at .028 on these new plugs.
    Will these coils be a straight swap? I'm not sure about the soldering you mentioned in your post? Do the newer coils have a different socket? I'd rather just do a clean swap...
    http://www.ecstuning.com/Volkswagen-...nition/ES7536/
  3. #23
    Dec 2007
    The site i bought my ignition sensor from has the same coils as mine for US$60 a coil.
    http://www.aboveallmotorwerks.com/BV...BERU_058905105
    I'm going to give my local dealership a call too.
  4. #24
    Feb 2009
    No they will not be straight swap because the newer coils don't need an ignition controller. Instead they have this on the coil itself to eliminate the need for it.
    You basically need to create a little harness to delete the ICM.
    058905105 are "old" style coils, just like mine.
    BMW 1M
  5. #25
    Dec 2007
    A quick update.
    The new coils and better gapped plugs have been running well, so all is good with the high boost issue.
    I still have the warm start issue though. I've just sent my mechanic an email to see when they'll be able to look at it...
