Hi, I know the mechanism pretty well. Do you hear the sound at all when you push on the handle ?
Hey again all,
Got the car back today after getting the coilovers installed and found when getting to work the boot wont open. The switch under the rubber feels different. Its the switch operated electric boot release on a bora.
Anyone had problems with this before?
Nathan
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
Na it does nothing at all, totally dead. Is there any other way to open it??
Nathan
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
Open up the back seat & remove the boot trim (many felt covered screws) Once removed, pull the rod that goes to the latch & the boot will open.
You then need to check the back of the switch or solenoid for voltage when switch is activated.
Jaimo.
06 Jetta/09 Pirelli/DSG
08 T5 BPC/Auto
08 Caddy Maxi life TDI/DSG
12 Up!.
Fixed!!! It was just the main switch had moved out and needed the pin re-seated. Could have been done without removing the whole boot lining and switch assembly. O well, at least ill know for next time!
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
Wow! that's a new one to look out for.
That's never been that simple for me, I've always needed to replace the solenoid or switch.
Well done!
Jaimo.
08 T5 BPC/Auto
12 Up!.
Jaimo do you know where I can get the black plastic bit that sits next the solenoid. It is a Carrier plate on VW's list but they want 80 $ for it !
And its done it again! grr new switch here we come!
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
Any chance of a pic, as I may have one somewhere.
jaimo.
08 T5 BPC/Auto
12 Up!.
hi all,
i have a similar problem at the moment,
when i go to the boot i hear the electrics making the open noise, but the boot doesnt open. It then makes a noise again like it is closing.
Any idea what I should do/what i need to fix it
cheers
