hi i recently had this the plastic bit breaks, boot no longer opens electrically does with the key.Attempted to glue it no joy may have to take it of and fabricate one. Rob mac.
It is quite possibly the black plastic clip has broken like on mine.
See part number 29 attached which is a carrier panel that has the plastic clip on it.
if you decide to fabricate one, please do one for me ?![]()
Hi,
Ive got problem with my boot as well - this time the boot will not shut! will stay down but not lock (so the dash light comes on luggage compartment open) the boot handle seems to work ok makes same noise but the latch is not catching at the bottom
You think electric problem or mechanical?
Suzuki Gti 89 & 93
Subaru WRX 97 & 99
VW Bora V6 4motion
I cant think of the component causing it but open it up and have a look.
Could be a faulty sensor, as I dont think it actually locks so much as doesnt respond to the open command when the car is locked. Thus turning the key will pop her open. But if its not locking more than likely it is something mechanical.
I am having my catch that broke made up. If anyone wants to get one let me know and I can find out how much depending on numbers.
Hi finally getting round to posting my work around.
Took it apart and ground the back of the thru rivet off, made a repair plate from thin ally glued it all back together with araldite rapid. After inserting some small screws to streghthen the part ,drilled and tapped the thru rivet and replaced all the parts. Electric boot works, well within the grasp of a competent diyer $$$ saved.
Audi B4 80 Q V6 '94 Race Car !! KEGGED
Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
--VW Bora V6 4mo '01 Gone
Attachment 3155
Attachment 3156
Attachment 3157
Attachment 3158
Some pictures of my handywork. Dont worry about the dustIt got on there when I was drilling
