Results 1 to 10 of 19
Thread: Problem with electric boot handle.....
    Sep 2007
    Syd, Northern Beaches
    Hey again all,
    Got the car back today after getting the coilovers installed and found when getting to work the boot wont open. The switch under the rubber feels different. Its the switch operated electric boot release on a bora.
    Anyone had problems with this before?
    Nathan
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    May 2007
    Moonee Ponds
    Hi, I know the mechanism pretty well. Do you hear the sound at all when you push on the handle ?
    Sep 2007
    Na it does nothing at all, totally dead. Is there any other way to open it??
    Nathan
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Apr 2006
    Nth of Nowra.
    Boot
    Open up the back seat & remove the boot trim (many felt covered screws) Once removed, pull the rod that goes to the latch & the boot will open.
    You then need to check the back of the switch or solenoid for voltage when switch is activated.
    Jaimo.
    06 Jetta/09 Pirelli/DSG
    08 T5 BPC/Auto
    08 Caddy Maxi life TDI/DSG
    12 Up!.
    Sep 2007
    Fixed!!! It was just the main switch had moved out and needed the pin re-seated. Could have been done without removing the whole boot lining and switch assembly. O well, at least ill know for next time!
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Apr 2006
    Nth of Nowra.
    Thumbs up
    Wow! that's a new one to look out for.
    That's never been that simple for me, I've always needed to replace the solenoid or switch.
    Well done!
    Jaimo.
    08 T5 BPC/Auto
    12 Up!.
    May 2007
    Moonee Ponds
    Jaimo do you know where I can get the black plastic bit that sits next the solenoid. It is a Carrier plate on VW's list but they want 80 $ for it !
    Sep 2007
    And its done it again! grr new switch here we come!
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Apr 2006
    Nth of Nowra.
    Any chance of a pic, as I may have one somewhere.
    jaimo.
    08 T5 BPC/Auto
    12 Up!.
    Dec 2007
    melbourne
    hi all,
    i have a similar problem at the moment,
    when i go to the boot i hear the electrics making the open noise, but the boot doesnt open. It then makes a noise again like it is closing.
    Any idea what I should do/what i need to fix it
    cheers
