If they do throw codes they generally are lambda related and that prompts the inexperienced to fit a Probe. Yeah these do go but you must read what it is doing. Funny but nowadays if the computer throws no codes then no problem???????? There still IS a problem and the basics get missed like the humble spark plug( im sure most of you would agree ) scanner can trap you if you dont look outside the square. Im talking from experience LOL!! To answer you MAF Q? H100W is 100% right the ecu defaults but its only a default map and wont run at optimum. There is a spot in VAG COm where you can read the intake % and match it to a KW output and that also gives you an idea that you have a MAF Fault. Another notorious sensor on these is the Brake pedal switch. When pressed it switches the fuel off. When faulty also does the same , And sometimes doesnt throw a code, but again you can do a function test on this item with VAGCOM
Good luck!
Alba European
