my guage only goes to 20... and it shoots past that...
on a K03 or K03S all 20 psi + of boost (1.3 bar) is going to do is prematurely wear out a turbo!
Even 1.4 bar on an S3 K04 is the maximum effecient boost!
17 psi is at the very, very top of a K03 compressor map.
Here is a thread from 5 years ago where they map a K03 in regard to a 1.8T engine.
http://forums.generationdub.com/showthread.php?t=4207
If you are making 24+ psi on a K03, check your boost guage / connection / location & make sure its fully accurate![]()
how do you guys get 20psi+?
boost controller?
MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
LOL, yeah there's nothing better than a boost gauge that adds 5-10 psi to your readings. Best bang-for-buck boost upgrade ever.If you are making 24+ psi on a K03, check your boost guage / connection / location & make sure its fully accurate
Snowy.
higher the betta![]()
