Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Poundege
    Jan 2008
    my guage only goes to 20... and it shoots past that...
    on a K03 or K03S all 20 psi + of boost (1.3 bar) is going to do is prematurely wear out a turbo!
    Even 1.4 bar on an S3 K04 is the maximum effecient boost!
    17 psi is at the very, very top of a K03 compressor map.
    Here is a thread from 5 years ago where they map a K03 in regard to a 1.8T engine.
    http://forums.generationdub.com/showthread.php?t=4207
    If you are making 24+ psi on a K03, check your boost guage / connection / location & make sure its fully accurate
    Aug 2007
    doncaster, vic
    how do you guys get 20psi+?
    boost controller?
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Canberra
    LOL, yeah there's nothing better than a boost gauge that adds 5-10 psi to your readings. Best bang-for-buck boost upgrade ever.
    Snowy.
    Nov 2006
    Had a quick read of that thread, seems 24psi is fine on the ko3S but not ko3. (Because it runs a ko4 compressor wheel = ko4 compressor map)
    Aug 2006
    higher the betta
