2004 gti agu dying under boost
hey everyone, my gti has been coughing and spluttering when ever it gets over 6psi and occasionally coming onto boost, i have already replaced the igniter booster box (bosch 0227100211) and fitted new spark plugs (ngk pfr6q) and cleaned the maf sensor, its still coughing and dying, any ideas?
100% stock apart from a 3" front pipe/turbo down pipe and a k&n panel filter.
thanks for any help
Have you run vagcom and retrieved codes?
Has the car ever boosted correctly with the 3" downpipe?
Yeah it's been running fine for months. Miss started last week, no error codes apart from the normal one for the dodgy air con motor.
Ok well unplugging the maf doesn't make a difference. Does that mean the maf is dead or does that mean it's not the maf?
- You may not post replies
- You may not edit your posts
Forum Rules
