Originally Posted by
Jono
Fuzion,
thank you so much for taking the time and helping me out. You've been more than helpful.
might consider a 2nd hand or chinese version later down then track...
realli liking the stock airboc CAI nice and cheap for me haha so ill prob do that
thanks again,
its all good.
in order and give you some help on pricing
$300 3" downpipe
$45 3" cai tube into stock airbox as per above
$220-140 Go Fast Bits (GFB) Plumb Back Diverter Valve
$45-95 dogbone mount bush replacement
$95-145 N75J valve (holds boost longer, electronic wastegate switch 'as say' you could call it)
$800-1400 chip (giac, revo, apr)
$20 mesh tt vent mod (behind intercooler, front of driver side wheel. refer to faq site above "Tt vent mod", allows more smic flow)
exhaust is not necessary to change until your making some better power outputs, however thats up to you.. if you do hiflow cat is NOT needed!
that should give you a break down on what to spend etc.
suspension is a matter of choice and funding allowance..
