Results 11 to 20 of 30
Thread: Pod Filter questions
    May 2007
    Moonee Ponds
    I like it, now that wud be worth doing
    Quote Originally Posted by JustCruisn View Post
    That thing is a heat sink for the ignition. Just cable tie it up near the firewall.
    It was put on the air box for better ventilation.
    I have BMC air intake, over priced for what it is, does bugger all but make noise, it is legal as it is enclosed.
    Have you looked into the Heineken setup ?http://forums.vwvortex.com/zerothread?id=4137466
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    May 2009
    Thanks for all the feedback guys!! Good points in different perspectives..
    Now I’m unsure on which path to go now haha
    Quote Originally Posted by balkanac View Post
    I had a POD filter on my car when i just got it and after a few months of having the filter the MAF died from the oil in the filter. This wasnt cheap to replace. Im not sure how it would affect the GTi engine tho. Id get the proper cold air intake, it makes so so so much difference especially on an FI car
    Quote Originally Posted by torque View Post
    A pod filter will filter less gunk then the original filter, it might cause premature MAF sensor failure; and/or more engine wear. It will also suck in hotter air from the engine than your original airbox design does I think ( unless it is properly masked inside the engine bay with separating walls and has an opening to get fresh air from outside ) ...
    I believe that the bad things it can potentially do does not make up for a bit of induction noise gained.
    But each to it's own
    I’ve heard that POD’s can ruin MAFs, so I’m pretty worried about doing that. Rather not do a mod that’ll cause problems in the long run. Thanks Balkanac and Torque for opening my eyes about possible problems, and not let me get caught up on induction noise lol.. I’m a bit of a sucker for Induction noise, but big picture if the MAF which I’m worried of breaking.
    Balkanac, what are some fairly good priced and recommended proper Cold Air Intake systems???
    Quote Originally Posted by Blitzen View Post
    Not really worth the percieved gains...Yes, you get the noise, but thats it. Increased intake tempreture will kill engine performance, and is illegal. Up to you though. I would look at a K&N panel filter, and a good diverter valve for extra noise.
    I’ve also considered the Panel Filter, not as much noise as I’d like. But safer approach problem wise for me anyways.. I know nothing about Diverter valves are they expensive? Easy to fit etc?
    I LOVE the Heineken setup hahah might visit the bottle-o this weekend heheh
    Feb 2008
    Quote Originally Posted by Jono View Post
    You Golf GTI comes with one stock. It is the black solenoid looking thing coming of the pipe that runs between your air box and your turbo, and has a smaller pipe running off it like a tail. You will probably know these better as Blow Off Valves(BOV's).
    A Diverter Valve (DV) is similar to a BOV. Both these valves work on manifold pressure, and prevent compressor stall(a slowing of the Turbo's compressor turbine caused by compressed air in the inlet pipe between the turbo and intake manifold when the throttle butterfly closes on gear change or when your foot is taken off the accelerator).
    This waste compressed air is expelled(in the DV's case) back to the intake side of the turbo when the DV is opened due to negative pressure(vacuum) in the inlet manifold.
    In the cas of a BOV, the air is expelled to either the intake and atmosphere(in the case of a Dual Port BOV), or just to atmosphere.
    This is a DV...
    http://www.forgemotorsport.co.uk/con...oduct=FMCL007P
    This is a BOV(both dual port and atmospheric...what I have on my GTI)
    http://www.forgemotorsport.co.uk/con...duct=FMDVSPLTR
    Both valves take about 10min to fit to your car, and all you need extra is 2 x 20mm hose clamps.
    Dec 2007
    That minikeg intake is tempting
    I'm thinking of doing what some others on the forum have done and run some piping from the stock airbox down the to the intake at the bumper.
    May 2009
    This is a DV...
    wow thanks for all the info!! im assuming the DV is quieter than a BOV?
    i can hear a faint noise with my stock DV wouldnt mind it being a little louder..
    Oct 2006
    Jono,
    heres a few ideas for you.
    Forge Splitter (50 recirc, 50 atmospheric) - wont throw any codes and will give you that desired sound your after if wanting so.
    Forge/Bailey/Go Fast Bits Diverter Valve (Plumback 100%) - with a stock airbox very minimal sound, however accompanied by a 'intake' it'll sound as loud as a 'blow valve' almost.
    AEM Intake is my pic (as attached with pic below of my engine bay) You can pick these up from Ebay but AEM is VERY expensive as they are a premium brand. (get on ebay, search "aem intake golf")
    Alternatively you could buy a Chinese Intake which is a AEM ripoff which i dont see why it wouldn't be any different, however you'd want to get an AEM, Pipercross or any type of DRY Airfilter so you don't ruin your maf.
    Apr 2008
    The potential damage to your MAF sensor being mentioned isn't strictly due to a pod filter as much as it is to an oiled filter. You can get oiled panel filters as well (and dry paper pods for that matter), and it's the oil in these filters which can, in theory, cause damage to your MAF if oil is sucked out of them into your intake and onto the MAF hot wire.
    Irrespective, as indicated, it's illegal to fit a bare pod filter, and it's likely counter productive as it would just end up sucking in warm air anyway (and you'll potentially end up with less power).
    Nothing to see here...
    Sep 2008
    Launceston
    I've had my GTI for a ~ 10 months now and it was fitted with a BMC intake when i purchased it. Im not sure how long it had been on there before i purchased the car, but i haven't had any MAF issues yet.
    Feb 2007
    Sydney NSW
    I've been running a POD on my GTI for over 2 years now without an issue.
    I'm yet to dyno the car and do a comparison and am interested in getting a full cold air intake but get scared when I read things like "becuase the flter is below the front bar,be careful when driving through heavy rain!"
    MK4 GTI | MK5 Sportline | 08 Audi S3
    Modify your ride with free DIY videos at www.mightycarmods.com
    Oct 2006
    im lucky as well, im careful where i go and try not use any boost at all whilst going through rain. mind you i have 2x diff air vents, 1 open 1 fully closed (weather dependant .. yes im that particulate lol)
    http://forums.vwvortex.com/zerothread?id=4360522
    http://forums.vwvortex.com/zerothread?id=4045487
    http://forums.vwvortex.com/zerothread?id=3238173
    theres endless threads ..
    you can also get a bypass from AEM as well, search ebay or google for that too .. worthwhile
    whilst yoru there
    http://www.youtube.com/watch?v=adxhQ1jkEn4 -dubaudi hydrolocked
