Results 1 to 10 of 19
Thread: Pod filter leaking boost?
    Apr 2015
    Wollongong
    Unhappy Pod filter leaking boost?
    I have a stock 01 mk4 gti, i recently bought a pod filter (only because i have a TIP that wont fit with the stock air box but didn't have it installed during this time period) and just clamped it onto the end of the maf. I usually get a peak of about 10psi with the air box and with the pod only about 6-7psi. i ran it for about a couple of weeks only really because the induction noise was nice and deep but replaced it again with the airbox and went back to 10psi. I cannot think of any way that is could be causing a drop in boost levels and cant find anything on the net about it. Maybe because the old 'hot engine air' being less dense and the turbo cant compress as much? Idk but yeah any help would be great.
    ps. i have no idea how to navigate forums so don't get too mad if this is in the wrong spot
    Thanks
    Dec 2008
    Sydney/Canberra
    Can't be leaking boost at the pod filter.
    I'd be looking elsewhere.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Apr 2015
    Wollongong
    that's what i thought, what do you think would be doing it? I didn't touch anything else. Thanks
    Jul 2012
    Sinagra, Western Australia
    Seems unlikely but the only cause I could see is that the filter is restricting flow.
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    Apr 2015
    Wollongong
    Well it was $16 from auto barn so yeah haha
    Lol. So is your ECU chipped/reflashed btw? 10psi the norm?
    Sent from the Batcave
    Using Tapatalk
    Nov 2013
    Bathurst
    Quote Originally Posted by theBRUCEofWAYNE View Post
    I peak 15 hold 14psi stock with a tweaked n75 but I see no way a pod could "leak" boost. Try a different brand pod?
    01 MKIV GTI ME7 converted hybrid k04
    08 MKV GTI Daily driver duties
    I have serious VAG issues.
    Apr 2015
    Wollongong
    Yeah ecu is all stock, I just realised it's ment to be a 'compact' pod filter so yeah it just must be restricting flow. Might go and buy a proper size one from super cheap for like $30 later on
    modify your stock air box.
    that and a clean filter will be a million times better then 90% of pod filters
    your pod wont be leaking boost, more like its suffocating it or similar as mentioned above
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2015
    Wollongong
    So you rekon like cut a hole in the airbox and route a pipe from the bumper or inside the fender to it or something?
