Originally Posted by
gpk_gti
ahhh,,forgot all about your measurements-sorry!!!
I had to fix mine aroung the window switches and ashtray.I removed the pieces then I rubbed it back with sand paper,untill all that "sticky" top layer paint was removed.Got myslef a can of matt black paint and proceeded to spray paint.after the first couple of layers,I gave it a light paper again,then gave it a final coat.
No marks! and looks original.You can remove the parts yourself and give it to your local spray painter,or got to ebay and get the r32 brushed aluminium set and ditch your stock painted part!!!
as well as that you can also use just a kitchen scrubber as well and it also wont leave any scratches and remove the rubber too and it just will leave a smooth plastic finish without having to spray it up again if you didnt want to!
