Results 1 to 10 of 17
Thread: Pioneer Headunit install
    Nov 2009
    NSW
    Hi Guys,
    I just got a pioneer DEH-X4850 BT head unit from JB hifi.
    https://www.jbhifi.com.au/gps-car-au...etooth/833821/
    What Pioneer - ISO adaptor do I need?
    I have a VW Golf MK4 2003 sport 2.0L model.
    Do I need to disconnect battery before installing new head unit?
    And any antenna adaptors required?
    Thanks,
    K.
    Jun 2013
    Spain
    Hey there! For that model you won't need any ISO adaptor. Just recently installed a Kenwood unit and just needed an antenna adaptor. Easy and donde in 15 minutes
    Enviado desde mi GT-I9505 mediante Tapatalk
    Nov 2009
    NSW
    You mean pull out the existing VW eurovox headunit and plug in the pioneer? Plug and play? What antenna adaptor do I need?
    Oct 2013
    Eastern Melbourne
    Head to your local autobarn and get them to help you out with the antenna adaptor. The aftermarket head unit's antenna connection is different to the one in your car. It's around $10-15 to buy and looks like a bullet.
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
    Nov 2009
    NSW
    Ok thanks. Autobahn is quite far from me any other stores I can get one from or online?
    Also do I need to disconnect car battery before installation?
    And to confirm I don't require a harness as the VW golf 4 already had the plugs ready to go? Ie just remove eurovox adaptor on the VW stock unit?
    Thanks,
    K.
    Oct 2013
    Eastern Melbourne
    Are you close to a Supercheap auto?
    This is the adaptor you're looking for: Aerpro Aerial Adaptor - Suit European, AP349 - Supercheap Auto Australia
    Yes, always disconnect the battery when working with car electronics for any number of reasons.
    With regards to the harnesses - if you dont want to cut up factory wires (which I wouldn't really recommend both because you need to know how to solder well and it's a huge waste of time) you will need an adaptor like this that connects your pioneer head unit wiring to a standard ISO connector.
    To better explain what's going on here:
    Your pioneer unit will come with a standard pioneer harness with loose wires - that looks like this. The manual will tell you what each of the wires do. The colours are standard for any aftermarket unit.
    Obviously for the unit to work in your car those wires need to link up car's wiring, which you will find is different in all cars compared to that of the aftermarket headunit's colouring and plug. How you do this differs from both car-to-car and installer. Most cars have own propriety audio harness/connector (e.g. this is a traditional audio harness that mitsubishi's have) and so you need to link the two together. You can do this by cutting the right wires and then soldering it on, but this is over-the-top and takes a lot of time to do plus you need to sus out which wire is what. What most people do these days is use "ISO" connectors which are mostly "plug in and play". For this normally would need two harnesses - one to convert the aftermarket headunit to the iso standard (e.g. Pioneer to ISO harness) and then an ISO connector the car in question. However in the case of the VW, it's propriety audio harness is the ISO connector so you only need the one.
    Hope that isn't too hard to understand.
    Top tips:
    1) Cross the red and yellow wires on the pioneer-to-ISO connector - so your headunit will run while the key is in ACC mode
    2) Don't use factory earth (black wire). Wire in your own. Connect the earth to a exposed metal. I used a bolt near the passenger door (remove panel).
    3) The rear of the radio housing will likely need to be cut up to properly fit the unit. Have a dremel/soldering iron/cutters ready.
    4) Buy a few spare fuses incase you short circuit one
    Nov 2009
    NSW
    Thanks.
    Cheers,
    K.
    Nov 2009
    NSW
    When I removed the stock VW single CD player the bracket stays in the dash. Is this normal or should it comes out attached with the player?
    If it's not meant to come out together how do I remove the bracket? As I want to fit the pioneer headunit with the supplied bracket? As when I try to insert the pioneer headunit with the stock VW bracket it does not lock into place.
    Thanks,
    K.
    Nov 2009
    NSW
    Hi guys,
    Hope someone can help.
    This is the picture of the bracket I'm referring to. Just afraid I will break the bracket in case I need to put the stock one back in.
    Cheers,
    K.
    Mar 2012
    Eastern Subs, Victoria
    Use a small screw driver to lift any tabs that are pressed in and then slide it out. You can straighten the tabs out once you remove it.
    Then slide in your pioneer bracket and push out the tabs on each side to secure it.
    Put the the screw and rubber knob of the original unit on the back of the pioneer, connect wires and slide it in.
