Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Pioneer Headunit install
    Jul 2007
    Brissy
    Pull out the pocket from above the radio. Gives a 2DIN opening, and much better access. Then lift up any tabs and you will be able to lift out that bracket no worries.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Nov 2009
    NSW
    Thanks for the info guys. What screw are you referring to? Also the original rubber that came with the VW headunit I can't use it on the pioneer as there is nothing on th eback of the pioneer that lets me plug it in.
    Also re the tray above radio, do I just pull it out with force?
    Mar 2012
    Eastern Subs, Victoria
    Take off the rubber knob on the back, unscrew the gold thread with an Allen key in the centre. Attach it to the back of the Pioneer. Not sure on the tray, but do not force it. YouTube might help.
    Nov 2009
    NSW
    ok thanks. What is the rubber used for? Is it essential to use it?
    Mar 2012
    It supports the back of the radio, I would use it but it's up to you.
    Nov 2009
    NSW
    ok thanks.
    Nov 2009
    NSW
    Hi Guys,
    Will I have the K-line issue if I use the pioneer to ISO harness?
    Thanks,
    K.
