Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: pic of your mk4 ... bora or golf
    Feb 2007
    Stock and not as nice as most on here but I like it still.
    Realistically, I'd like to get swaybars front and rear which would then pave the way for lowering in the future should I feel the need. I drive on horrible road everyday though so I'm in no rush to lower it. I'm not sure about wheels, I like RS4 copies but I think TT 6-spokes or Bora sports could look nice.
    Mk3.Mk4.Mk1
    My Mk1 Project
    Jul 2007
    Brissy
    Quote Originally Posted by madglf3 View Post
    That last pic really shouts - LOWER ME
    Feb 2007
    Haha, I know but if it were lower then I wouldn't have been able to drive it to that place, 4x4 style.
    Mk3.Mk4.Mk1
    My Mk1 Project
    HAHA yes!
    I like the first shot.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Albury, NSW Australia
    Here's a pic of part of my car . . .
    and here's what it looked like earlier in the year when it was driveable.
    Who says you can't take a low car over dirt?
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    Quote Originally Posted by YellowDieselGolf View Post
    Me... very bad experiences while looking for surf on un-named tracks
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2007
    What I've done to it
    List of current modifications
    APR ECU Upgrade –
    Valet, Stock, 98 and 104-Race Octane programs
    Fault Code Erase& Throttle Body Realignment
    Security Lockout & Anti Theft Programs
    Left foot braking custom code modification
    Sachs Rigid Clutch plate with organic special facings
    Sachs Performance Pressure Plate
    Front Peloquin Torsion Differential
    Rear Peloquin Torsion Differential
    OEM Shorter 4th 5th & 6th gears from VW 02M / FSM Gearbox
    VF Engine Mounts
    VF Pendulum Mount
    KW Variant 3 Coilover Suspension
    KW Springs in 2 different rates with linear and progressive sets
    KW Motorsport Adjustable Top Mounts
    OEM DSG Intake and Airbox to meet CAMS specs (same grams per sec intake of BMC intake but factory)
    APR / B&B Catback Exhaust
    HPA Haldex Orange Competition AWD Controller
    Forge Rear Adjustable Control Arms - top and bottom arms
    HPA Short shifter
    H&R front 25mm adjustable swaybar
    H&R rear 21mm adjustable swaybar
    H&R rear 15mm spacers
    Tomas Sport Tuning Rear Stress Brace
    Dieselgeek Panzerplate Skidplate
    Custom Fabricated Stainless Steel Brake Lines
    Pagid RS 4 Brake Pads for Rallies
    EBC Redstuff Pads for the Street
    Castrol SRF Race Brake Fluid or Motul 600
    Sparco #383 Steering Wheel
    Momo 8015 Hub
    Sparco Rally pedal set
    Monit Rally Computer
    Sparco Rally Navigators foot brace and Monit rally computer reset pedal
    OZ Superleggera Wheels – 6 Wheels total
    Toyo Proxes R888 R rated tyres
    Ecliptech 12 program shift light
    CAMS/ FIA approved Custom Fabricated Roll Cage
    CAMS / FIA approved Sparco Pro 2000 Seats
    CAMS / FIA approved Sparco 6 Point Harness’s
    CAMS approved 2 x 1KG Fire Extinguishers
    CAMS approved First Aid Kit
    CAMS approved safety triangles
    CAMS/FIA approved tow hooks front and rear
    CAMS/FIA approved secondary bonnet tether
    CAMS / FIA approved Kill Switch
    The car has a CAMS & AASA log books that allow it to be entered in CAMS / AASA / FIA sanctioned tarmac rally events in the M2C2 classification.
    The class specifications are as follow;
    M2 = Cars having a 0-60mph acceleration time from a standing start of 4.8 to 6.8 seconds in standard form.
    C = Contemporary 1998 Onwards
    2 = Capacity 2501cc to 3500cc
    Our thanks go to the following companies for their ongoing support and excellent service, without them none of this would be possible.
    Michael Weber Prestige and Performance
    Inmotive (KW Suspension)
    LEDA Suspension
    Norm Singleton Fabrication
    GP Cars
    Sign Masters Australia
    Dulvari Prestige Detailing
    Hornibrook Motorsport
    HPA
    VF Engineering
    What's left to do?
    After Mt Buller in December it will be pulled off the road, the bolt in full cage will be pulled out, what's left of the interior (carpets, head liner, door trims etc) will be stripped and the car will be seam welded and a full weld in cage will be installed to design specification from VW Motorsport UK as below
    other than that I'd love to ship it to Germany for the full HGP twin turbo kit but unfortunately I wouldn't be legal to run in any of the tarmac rally classes any more so for now that is out.
    Congrats if you've made it this far reading all that I hope I haven't bored you too much
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Apr 2008
    Bored Al? That's quite inspirational!
    My Bora:
    It goes in for a replacement replacement clutch and flywheel tomorrow (the original replacement from VW was dodgy). Also having the rear raised up a little so it sits at the same level as the front.
    It seems (this will be confirmed either way tomorrow) that the front sway bar is rubbing on the driveshafts. The noise is bloody annoying, and something will be happening to resolve it (adjustment of fitment is the ideal solution, then drop links, otherwise maybe a different swaybar to better suit a lowered car). Will have to see how things go.
    Future plans - not sure. Once the current issues are resolved, I really want to get it out on a track day and see how it goes - this will also give me a benchmark of sorts (for car and driver - I'd hope that I improve as well as improving the car over time!). I suspect I'll need to get a rear sway bar at some stage, and I'll probably sort out a rear brace of some kind too (like the TST brace). Rear control arms to deal with the camber issues inherent in lowering it, other than that, not sure really!
    Nothing to see here...
    Dec 2007
    Brisbane, Southside...
    The H&R sways that Al and I both have are made so they don't knock when the car is lowered. I'd dare say that they'd fit your car as well.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Apr 2008
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    And probably come as a matched front & rear pair...
