Results 1 to 10 of 10
Thread: Phantom Plug....
    Jun 2008
    Ringwood, Victoria
    Phantom Plug....
    Hi all,
    Was having a poke around under the bonnet yesterday, work is slow so I figure I may as well keep my car clean in the meantime
    One of the things I wanted to check was if the headlight adjusting dial actually worked as it didn't seem so the other night. Well it does!! Yay!
    While I had the rear headlight cover off, I noticed a stray plug, not attached to anything....the strange bit is, I couldn't even see anywhere that it might go????
    It's attached to the wiring loom for the drivers side headlight, has hot pink insulation inside it and is a 2 pin connector. The connector also rotates...
    Any Ideas??
    The top left of the image is the windscreen washer reservoir.
    A view from directly above. Plug is just below the fixing screw for the reservoir.
    Plug highlighted.
    This one is a real head scratcher for me...
    Wattle Grove, NSW
    I think it could possibley be for opional spot/fog lights
    Chris aka TSi2NV.
    MK6 Golf 90TSi.
    MODS: 20% tints, H&R Lowering Springs (45mm), 18" rims
    Jun 2008
    Sydney, The Hills
    Sounds like it may be, the GTI's come with the fog lights below the blinker unit, but in all the other models its usually just a plastic bump the looks like the fog light. I would presume it has the same wiring setup as the GTI's otherwise they would have to make seperate units, so its probably just the stray fog lead.
    Dec 2007
    Brisbane, Southside...
    Yep I agree, definitely looks to me like it would be for the integrated fog lights in the headlight cluster.
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Feb 2008
    New Zealand
    lol
    its none of those .. the foglights in the headlight cluster is all part and parcel with the main plug for the headlamps
    that plug right there seems to be an unimportant enginebay temperature sensor..
    tbh i dont even know why they have it.. ive unplugged mine on both my mkIvs on numerous occasions and nothing seems to ever register that its missing etc..
    dont worry about it
    the thing that its usually plugged in to usually has a silly plastic bracket thats clipped in to the back of the slam panel above that head light
    the sensor itself looks much like the one that resides down in the lower right handside of your bumper which registers the outside ambient air temp
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Dec 2007
    Quote Originally Posted by HitmanR32 View Post
    lol
    dont worry about it
    Not that I would know really, but it looks to me like it is coming from the headlight wiring?
    Jun 2008
    Sydney, The Hills
    lol
    Well thats my one thing i can learn for the day, my brain is now full
    Feb 2008
    New Zealand
    Quote Originally Posted by Treza360 View Post
    they yeah they are all bound yet they have nothing to do with headlight
    - 2010 Golf R
    - 1997 Golf VR6
    Jun 2008
    Ringwood, Victoria
    I initially thought it might have been for foggies, but it's only on the driver's side, is a very short lead and has no current, well no 12v current, with any lights on/off, engine on/off.
    dont worry about it
    It could be that, but the cord isn't long enough to reach anywhere other than around the part of the chassis rail under it, It would only reach the headlight if I REALLY forced it!!
    Maybe its for my missing super-go-fast-jet-pack thing...
    Feb 2008
    New Zealand
    really dont worry about it.. if your THAT worried get a VAG COM Plugged in and see if anything pops up
    - 2010 Golf R
    - 1997 Golf VR6
