Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: The Perils of the DIY Mechanic - to VCDS or to not VCDS
  1. #21
    Dec 2006
    Kilsyth, VIC
    I have a MacBook Pro here and use Parallels to run Windows. It works perfectly with VCDS (as well as pretty much everything else I have tried that needs some piece of hardware that is Windows only).
    As for cheap scanner vs VCDS. Many will be fine for clearing basic codes, resetting the service interval and probably most stuff the average backyard mechanic is likely to come up against... But if you're going to be tinkering much more than regular oil changes VCDS can be a handy thing to have around.
  2. #22
    Oct 2013
    Eastern Melbourne
    I haven't been this confused for quite some time!
    So some non official VAGCOM gear, like Actron, can clear codes and relay correct information about the car's 'health' ?
    (Can ABS/ESP code be cleared too?)
    What sort of stuff can it not do? I'm just wondering because if I can avoid having to pay $300 for the official VAGCOM gear then I will avoid it at all costs. A lot of other things on the car I'd rather spend the money on
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
  3. #23
    Jun 2014
    Quote Originally Posted by RubAVeeDubDub View Post
    So it reckons. It may however be limited in resetting service messages however i have a service due in 2000 kms so I'll let you know if it works or not...
    You need to unlock these options within the app though - i suggest downloading the u-scan app and checking out the functions yourself - its free from the app store
    But the product says it works with all 1996 + vehicles with obd2 and has the ability to clear codes - have a look at the review link i posted in an earlier post - it gives a pretty good overview of its capabilities. But once i get mine in a couple of weeks, i'll officially review it (with pictures) and let the VWW members be the judge
  4. #24
    May 2013
    Orange NSW
    I originally bought a microcan cable. This was really good exept it didn't work on the wifes car. I sold it and bought the hexcan cable. The Ross-Tech cable allows many things to be customised so the car is nicer on a daily basis. I have set mine to Euro as it allows me to use the high beam lights and the some other little things which are a bit quirky with the Aus setting. It allows each module to be set the way you want not the way the dealer dictated. Fault codes are saved into a txt file for review as well.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
  5. #25
    May 2013
    Quote Originally Posted by The_Hawk View Post
    Another option for Mac users is Virtual Box and the Microsoft XP virtual machine they ship for Windows 7... Both are available for the "right price"
    Sent from my GT-I9505 using Tapatalk
  6. #26
    Feb 2014
    Batemans bay
    My cheap n cheerful reader.... as said bought to clear a fault on a A6 but it checked and cleared any issues re Engine, ABS, Auto Trans and airbags on the Bora....
  7. #27
    Jun 2014
    Hmmmm will keep that one in mind! Cheers!
